- Két OLED kijelzőt is bevet a GPD DUO
- Notebook hibák
- Logitech Harmony - én irányítok mindent!
- Steam Deck
- Raspberry Pi
- Computex 2024: a GeIL memóriái között akad olyan, ami 10 GHz fölé merészkedik
Hauntii teszt
gp Ki gondolta volna, hogy az élet és halál közti rés ennyire élvezetes lehet? Igaz, szín nem sok fért ebbe a birodalomba, de a Hauntii hangulatával, harcaival és apró fejtörőivel is képes elvarázsolni.
AMD Ryzen 9 / 7 / 5 / 3 5***(X) "Zen 3" (AM4) topik összefoglaló
fudi2002
válasz MPowerPH #3779 üzenetére
Tessék:
Software[edit]StarCitizen (Game) Starting in version 3.11 onwards StarCitizens minimum requirements were updated to make use of AVX, the game engine is currently using DirectX 11, but is developing Vulkan API support for use in its modified Lumberyard Engine.Blender uses AVX2 in the render engine cycles.Botan uses both AVX and AVX2 when available to accelerate some algorithms, like ChaCha.Crypto++ uses both AVX and AVX2 when available to accelerate some algorithms, like Salsa and ChaCha.OpenSSL uses AVX- and AVX2-optimized cryptographic functions since version 1.0.2.[37] This support is also present in various clones and forks, like LibreSSLPrime95/MPrime, the software used for GIMPS, started using the AVX instructions since version 27.x.dav1d AV1 decoder can use AVX2 on supported CPUs.[38]dnetc, the software used by distributed.net, has an AVX2 core available for its RC5 project and will soon release one for its OGR-28 project.Einstein@Home uses AVX in some of their distributed applications that search for gravitational waves.[39]Folding@home uses AVX on calculation cores implemented with GROMACS library.Horizon: Zero Dawn Uses AVX1 in the Decima (game engine) and is the engine the game uses.RPCS3, an open source PlayStation 3 emulator, uses AVX2 and AVX-512 instructions to emulate PS3 games.Network Device Interface, an IP video/audio protocol developed by NewTek for live broadcast production, uses AVX and AVX2 for increased performance.TensorFlow since version 1.6 and tensorflow above versions requires CPU supporting at least AVX.[40]x264, x265 and VTM video encoders can use AVX2 or AVX-512 to speed up encoding.Various CPU-based cryptocurrency miners (like pooler's cpuminer for Bitcoin and Litecoin) use AVX and AVX2 for various cryptography-related routines, including SHA-256 and scrypt.libsodium uses AVX in the implementation of scalar multiplication for Curve25519 and Ed25519 algorithms, AVX2 for BLAKE2b, Salsa20, ChaCha20, and AVX2 and AVX-512 in implementation of Argon2 algorithm.libvpx open source reference implementation of VP8/VP9 encoder/decoder, uses AVX2 or AVX-512 when available.FFTW can utilize AVX, AVX2 and AVX-512 when available.LLVMpipe, a software OpenGL renderer in Mesa using Gallium and LLVM infrastructure, uses AVX2 when available.glibc uses AVX2 (with FMA) for optimized implementation (i.e.expf
,sinf
,powf
,atanf
,atan2f
) of various mathematical functions in libc.Linux kernel can use AVX or AVX2, together with AES-NI as optimized implementation of AES-GCM cryptographic algorithm.Linux kernel uses AVX or AVX2 when available, in optimized implementation of multiple other cryptographic ciphers: Camellia, CAST5, CAST6, Serpent, Twofish, MORUS-1280, and other primitives: Poly1305, SHA-1, SHA-256, SHA-512, ChaCha20.POCL, a portable Computing Language, that provides implementation of OpenCL, makes use of AVX, AVX2 and AVX512 when possible..NET Core and .NET Framework can utilize AVX, AVX2 through the genericSystem.Numerics.Vectors
namespace..NET Core, starting from version 2.1 and more extensively after version 3.0 can directly use all AVX, AVX2 intrinsics through theSystem.Runtime.Intrinsics.X86
namespace.EmEditor 19.0 and above uses AVX-2 to speed up processing.[41]Native Instruments' Massive X softsynth requires AVX.[42]Microsoft Teams uses AVX2 instructions to create a blurred or custom background behind video chat participants.[43]simdjson a JSON parsing library uses AVX2 to achieve improved decoding speed.[44][ Szerkesztve ]
Szakmai kérdésre privátban nem reagálok.
fudi2002
válasz Devid_81 #3786 üzenetére
Nos, ezt gondolom a hirtelen ryzen szakértő kollégától kaptad ezeket az ötleteket.
Hálistennek nem működnek, mert ha működnének akkor ebből még baj is lehetne...
Ha meglesed a képeid, akkor hol ppt limitben akad ki, hol pedig tdcben. (mindkettő gyári értéken, ha meglesed, 95anél illetve 140wnál) Eme két értéket biztosan nem birizgálnám a gyáritól felfelé. A tdc lesz az avx2 terheléskor ami elsőre kiakasztja a játékot, mert az amper ugye. A ppt lesz a "sima" terheléses, ahol kisebb az amper, de minden szál kihasználva, tehát 140w-os fogyasztási limit miatt áll meg. Ha limitálni akarsz valóban, akkor ppt mondjuk 130w, vagy tdc 90Szakmai kérdésre privátban nem reagálok.
fudi2002
válasz MPowerPH #3793 üzenetére
Nem az alaplaptól függ. Ha a pbo menüben belövöd, hogy a limiteket az alaplap kezelje akkor igen. Nagyon nem jó 5let ezt beállítani, egyik lapnál sem.(illetve lehet, de akkor offsetel vagy lekorlátozva) A többi beállításnál garantáltan ilyeneket nem fogsz látni.
Devid:
A gyári ppt 140w. Ezt belövöd 200w-ra, azért érzed ugye hogy ez nem a gyárihoz közeli érték?Szakmai kérdésre privátban nem reagálok.
fudi2002
válasz MPowerPH #3803 üzenetére
Nekik nem a tartós használat a cél. Ha rövidtávú szép tuningeredményeket akarsz látni, tökéletes.
"Bocs Mester, mindig elfelejtem, hogy egy korszakos zseni is van kozottunk."
Na látod, ezért nem fogok tippeket adni neked soha többet.[ Szerkesztve ]
fudi2002
válasz ScomComputer #3852 üzenetére
Jól sikerült a zen3. Meg a startja is..
fudi2002
Én nem feledem noctuának, mikor a d14hez kértem tőlük lefogatót am4re. Hivatalosan am4 lap kellett hozzá, írtam nekik hogy az rendelés alatt, d14 számláját elküldtem. 5 nap alatt kezemben volt ingyér a lefogató. Ez olyan support féle, amiért később egy d15t, majd azután egy chromaxot is tőlük vettem.
fudi2002
válasz Eugene Roe #4096 üzenetére
"az fclk szerintem semmit sem ér, feszes 3000mhz 1500fclk és feszes 3800mhz 1900fclk között shadow od the tomb raiderben 5% difi sincs, miközben az fclk és memória 27%-kal magasabb..."
Zen2nél ez nagyon nem így volt, olyan meggyőződéssel írtad ezt le, talán magad tapasztaltad?Szakmai kérdésre privátban nem reagálok.
fudi2002
válasz likeaRAINBOW #4232 üzenetére
Jólvan, de legalább nem msi féle bugokkal van tele.... Meg nem a lejjebb írt giga bugok..
Akárki fikáz itt bármi márkát, szimplán kiderült, agesa szintű gondok vannak...Szakmai kérdésre privátban nem reagálok.
fudi2002
válasz likeaRAINBOW #4234 üzenetére
Stimmt. Csak annyira fikázzák itt folyamat az msit, mert ugye minden más kafa. Sztem most fordulj azokhoz bizalommal akik Neked ezt ajánlották.
fudi2002
válasz likeaRAINBOW #4240 üzenetére
2ccds prociknál főleg sok lapmárkával és típussal küzdenek. Mind működni fog, a Tiéd is. Amdék vmit elkurbliztak a startnál.
fudi2002
A 0.9v socnak gyászosan kevés. Amúgy pedig 3900x mellett 3700mhzcl15, ryzen 3100 mellett 3733cl15el mentek a ballistixjeim szóval ez nem igaz. Mondjuk 1.0875v alatti soccal be sem próbálkoztam ilyen magas fclknál... Ő meg itt tolta el sztem.
fudi2002
A soc-vddp-vddg együttese nem volt rendben. Cl15 simán megy. Zen2nél garantáltan nincs ilyen gond, ne terjesszük. A gdm ha be van kapcsolva akkor a páratlanból a felette levő párosra kapcsol. Ha gdm off akkor meg az amit belőttél. Amúgy erősen ajánlott mellőzni a gdm ont, mikrolagot okozhat zen2nél biztosan.
fudi2002
válasz Devid_81 #4702 üzenetére
Igenis van olyan szempont, hogy halk gép. Oka: asszony.
Nekem pl fontos, hogy játék és laza terhelés alatt kussoljon a gép, mert az asszony kirak a garázsba a szarommal együttPersze a teljesítményről sem mondok le, akárcsak a meleg szobáról..
